doublejay Posted April 22, 2008 Posted April 22, 2008 hi gang transedit finds the whole range of dvb t chanels (freeview ) and previews with no problem. however, after sending them or importing themnto dvbviewern- many dont display i fear i have screwed up some settings - so i'd be gratful for some help please. support.zip Quote
doublejay Posted April 25, 2008 Author Posted April 25, 2008 I should also add - that DVB-S channels resolves and play without a problem. Maybe if 3.9.3 comes out of beta - I could do a re install ? Quote
doublejay Posted April 27, 2008 Author Posted April 27, 2008 little help ? or should I call the office ? Quote
hdv Posted May 1, 2008 Posted May 1, 2008 Hello, first, try the same decoder in DVBViewer like TransEdit. in DVBViewer you use as audio decoder the "MPEG Audio Decoder" but he is missing in your system. if the channels don't display any more, check if the stream is without errors start the DVB Source (View -> Filters -> DVB Source), is there any Discontinuities counted? Quote
