CanalDigital has moved the HD channels
Tyro
CanalDigital has moved the HD-channels from Thor 3,4 to Thor 5. Trying to scan Thor 5 give me problems that i can´t solve. When i chose Scan Channels I can´t find Thor 5 in the Transponder List. So what should I do to perform a scanning of Thor 5?
For you it's just a change of name. Only if the transponder frequencies or transmission parameters have changed, you have to perform a new scan.
If I scan Thor 2,3 the HD Channels are missing. But you can find the solution of this problem in the topic "Scan HD-channels on Thor"
