DVBServer Client
Ham Wong
I have sucessfully setup the DVBServer and works perfectly
but what I wanna know is DVBViewer Pro is the only software that able do the client work?
if so, is that mean I need to purchase many licenses for the client computer?
and is anyone may explain what is the difference of Unicast and Multicast?
Edited by Ham Wong
You can also use VLC Mediaplayer as a network client. It's free.
Link to software: http://www.videolan.org/vlc/
Don't ask me help to set it up, I don't know how >_<
Sir, I have try with VLC, which only works with Netsream Plug-in, but while use with DVB Server, not working...
Only the DVBViewer can connect to the dvbserver. The server has to be told, which channel to tune and which PIDs to send. It's like a networked DVB-card.
Within limits it is tolerated to use the DVBViewer on more than one of your computers, as long as the computers are in you living space (own house, flat etc). Obviously, if you live in a university dorm or something like this, this rule does not apply. >_< Just keep it sensible and within limits and remember each sold unit supports the further development of the DVBViewer.
