subtitle disappear suddenly
kclement
I had found my DVBViewer beta version cannot display any subtitle for 3.941 and 3.945.
I'm in Hong Kong with digital broadcasting system of DMB-T/H
Only the orginal 3.920 version works with subtitle.
Please help me! Thank you.
In Finland there has been no major problems with DVBViewer and subtitles (same with all those versions).
Are you using teletext or DVB subtitles? If DVB subtitles check that you have in options/subtitles "Enable if available" selected.
Settigs / subtitle should also show which dvb subtitles and teletext subtitles are availble in your brodcast, is there anything ?
It's a DVB subtitles and I have selected "enable" already.
The orginal 3920 PRO version can display subtitles correctly, while 3941, 3945 beta can't
both settings are same :rolleyes:
