Tearing if OSD skin size is smaller than resolution
AndersB
I am trying to get an acceptable image using nvidia gpu under vista. I currently use the NewDefHD skin in 1024x576. My display is running 1024x768 and I get severe tearing when the image pans horizontally. The tearing appears what seem to be exactly 576 pixels from the top of the screen which lead me to suspect that it has something to do with the OSD size. If I use another skin, for example the Default skin, with lower resolution the image get all pixely and way worse. I use nvidia codec and VMR9 without nvidia VMR fix. If I enable the VMR fix I get really bad pixelation in the image again.
Does anyone know why this happen and possibly the solution?
  • 8 months later...
I have the same problem.
The resolution OSD (MiniEPG) in SD channels he is very low. A the bit better on the knałach of HD.
Does someone know as to alter this?
I reverted back to XP and haven't gone back since. I use Vista on my other machines but the HTPC will stay on XP.
