PCTV Sat HDTV Pro USB (452e) and Vista x64
ramonchin
Hi
I have installed last BDA driver (still BETA) for this tuner, and it's Vista x32 and x64 compatible... Installation was ok, but DVBViewer says "No DVB device found"
Do you know any patch or fix for this problem?
I have Vista 64bits SP1
Thanks.
I have tried on other PC with Vista x86. Now the tuner is recognised and works fine, but can't tune DVB-S2 channels... Any sugestion?
