Frodo B Posted April 30, 2008 Posted April 30, 2008 Hello, I have a Technotrend S2-3200 with Common interface module. DVBViewer does not see the CI module. Do I need a plug-in for this problem? Thanks Bye Frodo B Quote
Lars_MQ Posted April 30, 2008 Posted April 30, 2008 Well not a plugin but the support dll for technotrend cards. You find it in the setup on the downloads page. You may also need the VC runtimes on the same page. Quote
CiNcH Posted April 30, 2008 Posted April 30, 2008 (edited) No, you have to install the DVBViewer with TT support. Chose to download components in the installer, then select TechnoTrend support and also make sure to check the installation of the VC2005 Runtimes for KNC/TT. Afterwards, the CI should work. Edited April 30, 2008 by CiNcH Quote
Clehner Posted June 13, 2008 Posted June 13, 2008 No, you have to install the DVBViewer with TT support. Chose to download components in the installer, then select TechnoTrend support and also make sure to check the installation of the VC2005 Runtimes for KNC/TT. Afterwards, the CI should work. Is there a way of getting CI support without connection to the internet? Thanks! Quote
