Overlay on Skystar 2 filter
boborg
Is there overlay when using Skystar 2 Filter 4.2x even if render output is set to Unchanged?
Colors look fine in DVBViewer but if I close it and then play a mpg in windows media player it looks very wrong. I have to go into nvidia graphics properties and reset overlay defaults.
It seems Marfi's filter does not suffer from it though... It too needs a reset overlay defaults when I switch to it from Skystar 2 Filter 4.2x.
Yes, but usually without the overlay mixer, that means you can't change the color settings. The render mode is not influenced by the source-filter.
IMO that's no problem of the DVBViewer's. I've tested Windows 2003 once and encountered that with every media player.
Bye, Oliver
Yes encountered too in Windows 2003. But thanks for your reply.
