barret Posted May 7, 2008 Posted May 7, 2008 (edited) I upgraded from DVBViewer Technisat edition to DVBViewer Pro 3.9.2. This is much better but channels with AC3 audio will not tune the audio pid. The audio pid tunes as 0. In channel edit I enter the pid manually and change the setting to AC3 from mpeg and the audio works. Also when using with the Techno Trend budget 3200 DVB-S2 card I have not been able to lock any of the DVB-S2 stations. I am unsure if I am doing something wrong? Chris Edited May 7, 2008 by barret Quote
barret Posted May 12, 2008 Author Posted May 12, 2008 (edited) I upgraded from DVBViewer Technisat edition to DVBViewer Pro 3.9.2. This is much better but channels with AC3 audio will not tune the audio pid. The audio pid tunes as 0. In channel edit I enter the pid manually and change the setting to AC3 from mpeg and the audio works. Also when using with the Techno Trend budget 3200 DVB-S2 card I have not been able to lock any of the DVB-S2 stations. I am unsure if I am doing something wrong? Chris It took me a while but Ihave it . DVB-S2 feeds are locked good with Trans Edit Pilot on AC3 audio problems only on select Fox Sports Feeds. Never did get audio to tune on these. Edited May 12, 2008 by barret Quote
