themaster1 Posted May 11, 2008 Posted May 11, 2008 (edited) I love DVBViewer but there is something really odd. See pictures below, respectively normal & via the tv remote (i use the OSD blue input) So in essence, i cannot go back to the previous directory directly via the tv remote unless i go back to the top of the filelist and when you have 500 files within a folder it's totally messed up. Thanks for adding such an option as soon as possible. Edited May 11, 2008 by themaster1 Quote
themaster1 Posted May 12, 2008 Author Posted May 12, 2008 Ah damn you're right, it's osd yellow which does the trick, nevermind then Quote
