Snoods Posted May 13, 2008 Posted May 13, 2008 (edited) I am really pleased with the performance of DVBViewer it works great for me. I have a slight annoyance on one of the HD channels and was wondering if anyone can help. I am using Vista 64 Bit and the Vista Enhanced Renderer with the Cyberlink H.264 codec with outstanding results on both BBC HD and ITV HD. The only problem i have and can't work out what's causing it, is i have a slight pause in the video every 2 seconds on Luxe TV. Does anyone know why Luxe TV should be different from BBC HD which plays perfectly? I have tried various settings but it's always the same jerky video. If i use another video renderer with Core AVC H.264 codec Luxe TV plays fine but i much prefer the quality i get from the Vista Enhanced Renderer and would much prefer to use this. Any suggestions would be most welcome. Edited May 13, 2008 by Snoods Quote
frankdsl Posted June 19, 2009 Posted June 19, 2009 I am really pleased with the performance of DVBViewer it works great for me. I have a slight annoyance on one of the HD channels and was wondering if anyone can help. I am using Vista 64 Bit and the Vista Enhanced Renderer with the Cyberlink H.264 codec with outstanding results on both BBC HD and ITV HD. The only problem i have and can't work out what's causing it, is i have a slight pause in the video every 2 seconds on Luxe TV. Does anyone know why Luxe TV should be different from BBC HD which plays perfectly? I have tried various settings but it's always the same jerky video. If i use another video renderer with Core AVC H.264 codec Luxe TV plays fine but i much prefer the quality i get from the Vista Enhanced Renderer and would much prefer to use this. Any suggestions would be most welcome. Same Problem. No solution so far, anyone? Quote
fundom Posted June 19, 2009 Posted June 19, 2009 This to confirm that Luxe TV does cause some problem. I, being a layman, could only relate it to its rather differrent resolution (1280X1088 off Eurobird 9A). However in my case & stream from this satellite, I don't get occassional pause, but instead I get flashing pixels, knotted into size of,say, 5mm to 8mm. But that is gone if I restart DVBViewer. Quote
dvbrewer Posted June 19, 2009 Posted June 19, 2009 (edited) This to confirm that Luxe TV does cause some problem. I, being a layman, could only relate it to its rather differrent resolution (1280X1088 off Eurobird 9A). However in my case & stream from this satellite, I don't get occassional pause, but instead I get flashing pixels, knotted into size of,say, 5mm to 8mm. But that is gone if I restart DVBViewer. Luxe seems to be unreliable for me too, but I think it may be due to being a high Eurobird frequency and my small dish has trouble with these channels. Sometimes switching codecs i.e. to ffdshow can make the problem go away, but then I just switched back to PDVD9 and the problem is no longer there either . Edited June 19, 2009 by dvbrewer Quote
