schumi4ever Posted May 13, 2008 Posted May 13, 2008 Hello, I am running Sky satellite through my technotrend card with a CI module, and it all works fine. However the EPG only displays 2-3 future programs that are coming up on each channel, instead of a full 12 hours or more of data, for me to pick programs to watch. How do I get it to show more? At the moment I'm having to either set the timer manually, which is time consuming and often cuts off a bit at the beginning/end, or I have to choose the program via the EPG window half an hour before the program starts, so that the program I want to record is actually displayed in the EPG window. What is wrong with it? Please help. Without it I can't really use DVBViewer properly! Quote
Lars_MQ Posted May 13, 2008 Posted May 13, 2008 Well you get all the epg, your broadcasters transmit. You could try XMLTV for more epg. Use the search for it Quote
schumi4ever Posted May 13, 2008 Author Posted May 13, 2008 Ha I did it! Channel EPG straight from the radiotimes website into DVBViewer using that XMLTV and XMLTVGUI programs. Superb. Quote
