shahed26 Posted May 14, 2008 Posted May 14, 2008 i love DVBViewer, tried many tv applications in the past, but this is the best. the only problem i have is, i select for my audio decoding cyberlink audio decoder 8, and then i rebuild graph, but DVBViewer v3.9.2 never uses it. its always using microsoft's mpeg audio decoder.. am using power dvd 8 (latest version) on a clean install vista ultimate x64 with no codec packs installed. only powerdvd 8 and its codecs. the video uses powerdvd 8 codec but the audio is always ms mpeg audio... please help me as i love cyberlinks audio "neo 6" feature., and just want DVBViewer to use only powerdvd's audio codec. last time before i did a clean install of my OS, DVBViewer was using cyberlinks audio decoder as i selected this as default. but this time after a clean install of my vista x64, i just could not get DVBViewer to use this codec thank you
Benarty Posted May 14, 2008 Posted May 14, 2008 Post a support.zip file. http://www.DVBViewer.info/forum/index.php?showtopic=2210
Lars_MQ Posted May 14, 2008 Posted May 14, 2008 Cyberlink audio decoder does not work anymore without a second decoder. Nothing we can change about this. you could use AC3Filter...
shahed26 Posted May 14, 2008 Author Posted May 14, 2008 Cyberlink audio decoder does not work anymore without a second decoder. Nothing we can change about this. you could use AC3Filter... thanks, but as i did mention, before i did a clean install of my vista i had cyberlink audio decoder working with DVBViewer 3.9.2, but when i installed my vista again, i just couldn't get it to work. currently using ac3 decoder.. my speaker setup is 6.1 and i just want my old config with cyberlink using the NEO:6 feature from the codec which sound awesome. thanks
shahed26 Posted May 14, 2008 Author Posted May 14, 2008 i love DVBViewer, tried many tv applications in the past, but this is the best. the only problem i have is, i select for my audio decoding cyberlink audio decoder 8, and then i rebuild graph, but DVBViewer v3.9.2 never uses it. its always using microsoft's mpeg audio decoder.. am using power dvd 8 (latest version) on a clean install vista ultimate x64 with no codec packs installed. only powerdvd 8 and its codecs. the video uses powerdvd 8 codec but the audio is always ms mpeg audio... please help me as i love cyberlinks audio "neo 6" feature., and just want DVBViewer to use only powerdvd's audio codec. last time before i did a clean install of my OS, DVBViewer was using cyberlinks audio decoder as i selected this as default. but this time after a clean install of my vista x64, i just could not get DVBViewer to use this codec thank yousupport.zip
shahed26 Posted May 14, 2008 Author Posted May 14, 2008 Post a support.zip file.http://www.DVBViewer.info/forum/index.php?showtopic=2210 thanks, posted my zip file, hopefully it will be fixed soon
Lars_MQ Posted May 14, 2008 Posted May 14, 2008 Get a legal version of the DVBViewer. No support for thieves. Thread closed.
