mcflurry Posted May 15, 2008 Posted May 15, 2008 Dear Arthur, Thank yopu for your good software. Recently i bought a new USB TV Strick " AverMedia AVerTV DMB850 Plus A850", DVBViewer can find out A850 , but cannot find out any channel although has signal, now i can only use its bundle software , but it is very bad ,please help me, thanks! The following links is the driver download page of " AverMedia AVerTV DMB850 Plus A850" http://www.avermedia.com/avertv/Support/Do...iver&id=437 Quote
mcflurry Posted May 15, 2008 Author Posted May 15, 2008 (edited) i use vista ultimate 32bit and use the latest driver 1.0.0.11 Edited May 15, 2008 by mcflurry Quote
mcflurry Posted May 19, 2008 Author Posted May 19, 2008 i have tried the mce driver , but it also cannot find out any channel, please help, thanks! Quote
westrail Posted May 22, 2008 Posted May 22, 2008 (edited) actually, this 'stick' is both compatible for DVB and DMB, the China Digi-TV format. i know that for those who only support DMB would be able to watch the TV by DVBViewer, it seems that the 'stick' or the software has just been automatically chosen the DVB as the only system for channel searching. Arthur, would you mind edit the program to fit for this suitation? just like adding a plug-in/program to 'cheat' DVBViewer, the TV 'stick' is just simply support DMB. the following link is the official player download site, you may take it as reference: http://www.avermedia.com/AVerTV/Support/Do...mp;tab=APDriver AVerTV & Aver MediaCentre are both suitable for it. Edited May 22, 2008 by westrail Quote
superpeter Posted June 23, 2008 Posted June 23, 2008 yes, i am using this usb tuner @ hong kong now, and it is the dmb-th system, but DVBViewer cannot scan the channel successfully.......please add this hardware support. because it is a good design tuner with style and provide reliable performance. Quote
Lars_MQ Posted June 23, 2008 Posted June 23, 2008 If it has a BDA driver it should work (-S/-C/-T). Quote
superpeter Posted June 24, 2008 Posted June 24, 2008 If it has a BDA driver it should work (-S/-C/-T). do you mean it is the driver issure, the avermedia dmb850 driver dont support the third party viewer? Quote
CiNcH Posted June 24, 2008 Posted June 24, 2008 (edited) BDA is a standardized interface which the DVBViewer uses. It has been proven to be properly used in combination with hundrets of DVB adapters. If AverMedia does not feature such a driver or does not implement BDA properly, then DVBViewer is a no-go. Edited June 24, 2008 by CiNcH Quote
WILLIAM YUNG Posted June 29, 2008 Posted June 29, 2008 BDA is a standardized interface which the DVBViewer uses. It has been proven to be properly used in combination with hundrets of DVB adapters. If AverMedia does not feature such a driver or does not implement BDA properly, then DVBViewer is a no-go. i looked at the menu settings ->option -> hardware -> the name mentioned of device is "Avermedia A850 BDA Digital Tuner", Does it mean it is the BDA driver? Quote
tweiske Posted October 5, 2009 Posted October 5, 2009 anyone found a solution for this device ? Hi there, it works. AverMedia has BDA drivers. Go to http://www.avermedia.com/AVerTV/Support/Do...spx?Type=Driver I tested Win7 drivers for "AverTV Volar Black HD A850", you can downloed the driver from the driver section. If you need drivers for Win XP, AverMedia does not supply drivers directly. Download the AverTV Application, that has all drivers embedded. Use an extraction program, e.g 7zip or uniextract (google) to extract the archive. Do not install! Go to AP6\drivers\default and extract Setup_x86.exe with 7zip or uniextratct. The driver is now in folder setup_x86. Control-Panel->System->device-manger, locate "unknown device", update driver and point to the driver folder "setup_x86"... done. Tommi Quote
