Doesn't scan the Tv Vlaanderen new frequency+don't see any fre
indieke
When I use the scan of DVBViewer, it will put the old TvVlaanderen frequencys not the new one's.
Also during a scan, I don't see after that any HD on Astra 19.2 (don't have another satelite!)
Now I heard abourt channel list in txt format. Am I wrong that this can be put in the software. If this would be illegal, please ignore this last question or delete it.
If it can be used, how does it work and what do I have to do! My English is not so good.... :bye:
If you change the first line of the TV-Vlaanderen transponder file to this:
Code:
"473833"="12721000, 22000, H, POS_1, FEC_56, DVB_S, QPSK, ROLL_20, P_ON"
Then you should be able to scan the frequencies.
if not, then start the channel editor and edit the old frequency:
Change frequency from 12669 to 12721 (or 12722)
Change vertikal polarisation to horizontal
change TID (Transponder Indentifier) from 1116 to 19999
Do this for the channels:
Éen
Ketnet/Canvas
VTM
2BE
VT4
Vitaya
kanaal 5
JIM
Kanaal Z
ActionNow
Radiostations:
Radio1
radio2
Donna
Studio Brussel
Klara
Q-Music
4FM
All other channels stay on their original frequency
Code:
Éen
Ketnet/Canvas
VTM
2BE
VT4
Vitaya
kanaal 5
JIM
Kanaal Z
ActionNow
Radiostations:
Radio1
radio2
Donna
Studio Brussel
Klara
Q-Music
4FM
Thanks, will do that. Everything works flawless for the rest now!
hmm topic was erased???
Correction: TID should be 1999
not 19999
  • 4 weeks later...
I am still in touble. I managed for the TVV Vlaanderen without any problem.
Now I have a HD display and I try to find
Astra HD Promo
Anixe HD
These are fta and on 11 914, 5
But when I try to scan that frequency in the channel list editor, it doesn't find anything.
Worse, I can't put a "," comma sign to specify better.
What should I do to put these stations for demo in my channel list
Thank you.
Do you have a DVB-S2 card?
Yes, a technotrend S 2 3200. The problem is that I can't find the HD channels in the channellist, and as the "comma" does not apply, how to search for them....
Try to scan with TransEdit. Here's my ini for 19E :)
Thanks, I will see if I can manage with that.
Scanned with the new list, still can't find them.
Does somebody know under which provider they should be?
Astra HD+ and anixeHD:
11,914Ghz so scan 11914 and nothing else
Polarisation : Horizontal
Scan only this frequency.
So do not scan a range.
I had trouble to scan the TV vlaanderen channels automaticly but a scan on the exact frequency could find them.
Edited by Benarty
  • 1 month later...
I had exactly the same problem.
Take away the original CAM of TVV and the HD channels appear.
I tried with the ASTON CAM and it works well.
I had exaclty the same problem as well...
I now use the Aston Seca CAM and it works really well...
I contacted TVV helpdesk to inform them of the issue and they arrogantly told me that the official CAM should work... You can only get support if you use one of their certified STBs...
