Problem with Avermedia A700 Dvb-S Pro
ramidusus1
Hello.
I have an Avermedia A700 Dvb-S Pro card and would like to use DVBViewer as my main program. On the other hand, I can only find one satellite for Pos A/Opt A when I search. Whereas, I am using a diseq switch that has four port. For this reason, I would like to ask you whether a version that supports Avermedia A700 with four ports diseq or not. Or it will be release soon. Thank you.
  • 2 months later...
I have the same probem. I'm supposed to see channels from two satellites But I only receive from one !
I tried ProgDVB,TransEdit,PowerCinema .. and all give the same result
But when I use AverTV that comes with card software I got the channels correctly as supposed to be.
I contacted Avermedia support today and now waiting for replay.
are you still havign this problem ?
