Start DVBviewer with green button on mce remote
lout
Hi plz its possible some how remap green boton on mce remote from media center to start DVBViewer on (vista)thnx
Have a go with LM Remote Keymap.
I can't recommend this more highly - basically it's a replacement for Media Center's own remote service, and one of its features is that it allows you to configure the keys of the Media Center remote that Media Center itself "hogs" i.e. the green button, Guide etc.
There's a bit of faffing about required to disable ehtray.exe, see the last post of this thread here.
Starting with version 4.4 of LM RKM you do not need to bother with ehtray.exe, there is a new option "Exclusive use..." that disable the native mappings of Media Center (for Green button, Live TV, Guide, Recorded TV and Power button).
Regards,
Stéphane.
Regards,
Stéphane.
Aha! Even better - thanks - I've been really impressed with this.
As an aside, how do you maintain the "normal" Green Button operation with a profile attached to Media Center itself i.e. I'd like a press of theGreen Button to bring me back to the Media Center home screen when I'm elsewhere in Media Center itself...
Edited by c128
  • 3 weeks later...
Did you find out how to do this ?
Use the keyboard shortcut Win Key + Alt + Enter (other WMC shortcuts).
You'll have to use the KeyUp and KeyDown actions in LM RKM:
* KeyDown / Menu (or LeftMenu / RightMenu) (Menu is the real name of "Alt")
* KeyDown / LeftWindows
* KeyDown / Return
* KeyUp / Return
* KeyUp / LeftWindows
* KeyUp / Menu
Regards,
Stéphane.
