arach Posted May 21, 2008 Posted May 21, 2008 (edited) Hello, I've noticed that DVBViewer crashes whenever Vista's UAC pops up. After the crash if I try to open the program again it will cause a blue screen. I normally do a lot of multitasking with my computer and this of course means that while DVBViewer is open, I can't do anything that would require UAC's attention. Since this is the only problem I have with the program, I guess it's got something to do with DVBViewer's compatibility (or the lack of it) with Vista and maybe that should be improved. I know many have hatred towards the OS, but it's very good if the programs are just made to work for it. My TV is AF9015, motherboard is Asus P5K and GPU is 9800 GTX with newest drivers. My OS is Vista SP1 and this is all shown in the support.zip I attached as well. support.zip Edited May 21, 2008 by arach Quote
Lars_MQ Posted May 21, 2008 Posted May 21, 2008 First thing: this has never been reported. second thing: this is not a complete support.zip, please check your installation third thing: never ever install ther DVBViewer in vista in usermode=0. Quote
Valts Posted May 22, 2008 Posted May 22, 2008 First thing: this has never been reported.second thing: this is not a complete support.zip, please check your installation third thing: never ever install ther DVBViewer in vista in usermode=0. It's not reported because it's not a problem of DVBViewer. I have DVB-T based on AF9015, it bluescreens vista 64 regulary with or w/o DVBViewer . Only solution I've found is to use XP 32bit. Quote
arach Posted May 24, 2008 Author Posted May 24, 2008 What do you mean with usermode=0? In usermode.ini it says so, but what does it mean? I re-installed my DVBViewer in Vista's super admin account and it still shows usermode=0. Quote
Tjod Posted May 24, 2008 Posted May 24, 2008 You have selected in the setup to storage the config files in the Program folder. That do not work in Vista. http://www.DVBViewer.info/forum/index.php?...st&p=150777 Quote
arach Posted May 24, 2008 Author Posted May 24, 2008 Well, I installed it with usermode 2 now. I did a couple of tests and DVBViewer didn't mind the UAC pop-ups at all. I don't know if it was just about the usermode, but it seems to be working now. Thanks Quote
