Preview function with high definition services
ginacman
Hello,
Using latest DVBViewer, I'm trying to use the preview function, sending a HD program back and forth (tried several ones) to/from the main window. The two active feeds are one from DVB-S2 and one from DVB-T. While preview function works well until I use two SD feeds, if the first of the two is SD and the second is HD, it is not possible to sent this latter to the shrinked window.
Thank you for any help.
