zoidberg77 Posted May 26, 2008 Posted May 26, 2008 hi just got DVBViewer about a week ago and everthing works great except for 1 thing. i get a hd channel for my local cabel provider(stofa in denmark) called Canal+ HD, witch is just black screen. i can hear the audio but no picture. i been searching the board for any clues to no awail. tryed it with powerdvd8 ultra and CoreAVC decoder in every render setting and video format detecion on/off. anyone got any ideas about what the problem might be? my rig is : winxp pro sp3 duo core E6550 2.33GHz 2 GB ram Geforce 8800 GTS Forceware 175.16 FireDTV/C FW Ver.: 2.4.0 Build 51440 Driver : 4.8.0 any help/idea will be much appreciated. Quote
maier2505 Posted May 26, 2008 Posted May 26, 2008 (edited) hi just got DVBViewer about a week ago and everthing works great except for 1 thing. i get a hd channel for my local cabel provider(stofa in denmark) called Canal+ HD, witch is just black screen. i can hear the audio but no picture. i been searching the board for any clues to no awail. tryed it with powerdvd8 ultra and CoreAVC decoder in every render setting and video format detecion on/off. anyone got any ideas about what the problem might be? my rig is : winxp pro sp3 duo core E6550 2.33GHz 2 GB ram Geforce 8800 GTS Forceware 175.16 FireDTV/C FW Ver.: 2.4.0 Build 51440 Driver : 4.8.0 any help/idea will be much appreciated. Hi, zoidberg77 ! Did you install any H.264 decoder ? And did you choose it for H.264 as standard in the options ? Please provide your support.zip... Another hint: I am using the Firedtv-C , too... The last two Firmwares have problems with H.264 channels, revert to the older Firmware Version could help. Best regards maier2505 Edited May 26, 2008 by maier2505 Quote
zoidberg77 Posted May 26, 2008 Author Posted May 26, 2008 Hi, zoidberg77 ! Did you install any H.264 decoder ? And did you choose it for H.264 as standard in the options ? Please provide your support.zip... Another hint: I am using the Firedtv-C , too... The last two Firmwares have problems with H.264 channels, revert to the older Firmware Version could help. Best regards maier2505 thanks for the snappy replay maier2505 H.264 decoders i have tryed are as followes. Cyberlink H.264/AVC Decoder(PDVD 8) CoreAVC Video Decoder ffdshow Video Decoder and yes i have tryed to switch around between em in options>DirectX with zero luck. and i will try with a older version of the firmware. support.zip Quote
