efla Posted May 26, 2008 Posted May 26, 2008 Hello, is it possible to have DVBViewer acting as TVServer for MediaPortal ? Thanks Quote
Derrick Posted May 26, 2008 Posted May 26, 2008 DVBViewer for DVBViewer ..you can use any generic client that can handle tcp/ip from the netstreaming plugin but only as a passive client like e.g. the VLC. Quote
atramhasis Posted July 16, 2008 Posted July 16, 2008 Two questions: 1. Why is only a passive client possible and could a plugin circumvent it? 2. Is the other way roud possible? TVServer from MediaPortal and DVBV as client (with EPG, channel switching...) Quote
hollymolly Posted July 17, 2008 Posted July 17, 2008 anybody wants tvserver from mediaportal?! the other way round - the fast and performant, stable tv engine from DVBViewer and the client ui from mediaportal, right? Quote
efla Posted September 4, 2008 Author Posted September 4, 2008 <br />anybody wants tvserver from mediaportal?! the other way round - the fast and performant, stable tv engine from DVBViewer and the client ui from mediaportal, right?<br /><br /><br /><br /> Yes it's exactly what I want 1) the fast and performant, stable tv engine from DVBViewer 2) the fast and performant, stable media management from Mediaportal Is it just a dream ? Quote
Lars_MQ Posted September 4, 2008 Posted September 4, 2008 hmmm fast, performant, stable and mediaportal in one sentence. This sounds so wrong on sooo many levels Quote
Bjur Posted October 13, 2008 Posted October 13, 2008 DVBViewer for DVBViewer ..you can use any generic client that can handle tcp/ip from the netstreaming plugin but only as a passive client like e.g. the VLC. I'm just opening this one again. I'm split between using either mediaportal or MCE, but either way I want to use DVBViewer as default TV player. When you say passive client do you mean in Media Portal you can just switch channels, but not do recordings etc? And is there an application that when you press a button, it will exit media portal and go to DVBViewer, and when you exit DVBViewer it will go back in Media Portal? Quote
