Kung Foo Posted May 26, 2008 Posted May 26, 2008 I've set up a successful installation of DVBViewer Pro V3.9.2.0 with Terratec Cinergy DVB-C C. Now I'd also like to try to run the DVBViewer as a client using my primary PC as a server. I tried to read the manual and configure the settings correctly (unicast), but no success. Could someone point me to right direction? A dummies example please? PS: Following this manual page did not yet get my installation to work: http://www.DVBViewer.com/en/index.php?page...er=g⊂=g5 Quote
Derrick Posted May 26, 2008 Posted May 26, 2008 ..more input please -> support.zip A common mistake is a missing or incorrect channel list on the client. Quote
Kung Foo Posted May 27, 2008 Author Posted May 27, 2008 A common mistake is a missing or incorrect channel list on the client. Ok, I now got the DVBViewer client to recognize the DVBViewer server (Settings->Hardware->Settings->Discover). But when I try to scan for the channels (Channel->Channel scan->Scan Frequency | Scan Range), no channels are found. By default the "Reception type" in channel searching is set to Satellite (the scan can be started, but does not find anything). If I change it to cable, the client does not even let me search the channels. So how do I build up the channel list? Quote
Lars_MQ Posted May 27, 2008 Posted May 27, 2008 You did tell the DVBViewer that this network device is a cable tuner type, didn't you? Quote
Kung Foo Posted May 27, 2008 Author Posted May 27, 2008 You did tell the DVBViewer that this network device is a cable tuner type, didn't you? Just as I pressed "send", I figured this one out When I switched to "cable", and copied the channel list & favorites files from the server PC, the client started working! Thanks! Quote
