cmapa Posted May 30, 2008 Posted May 30, 2008 (edited) Hi. Just updated Cyberlink from 3730 to 4102. When i did that the HD channels(H.264) starts jitter a lot i DVBViewer. uninstal the 4102 version and back to the 3730 version and the problem was gone. The problem is that i need to have the latest version to run new BD-movies from my LG-Combo. Anyone have the same problem? Is this related to old version(3.9.2) or...? As you may understand i using the codec from Cyberlink in DVBViewer(and have done so over years) Regards C Edit: It seams that it's not using hardware acc even if the radiobutton is on when looking in filter/vmr7 Edited May 30, 2008 by cmapa Quote
cmapa Posted June 4, 2008 Author Posted June 4, 2008 Just instal the 3.9.4 and have the same problem with the new 4102 rel from CyberLink. Same result so i have to use the 3730 version. Is there no one else using DVBViewer together with these version above? C Quote
dmcq Posted July 22, 2008 Posted July 22, 2008 4102 breaks hardware off load to video card. I use HD 2600 and HD 3400, they run at 3% CPU with BBCHD using Cyberlink 3730. using 4102 CPU shoots up to 95% - its broken. dmcq Quote
