madbaker Posted May 30, 2008 Posted May 30, 2008 I have just downloaded & installed 3.9.4.0, it seems to be much more responsive, channel changing is much faster now. One thing id love to know & not specific really to this build, Can DVBViewer be told to start with the channel list open already? Its a pain to have to keep on opening it everytime I run DVBViewer.. Nick Quote
Tjod Posted May 31, 2008 Posted May 31, 2008 Edit your shortcut to ...\DVBViewer\DVBViewer.exe -x7 or for the OSD channel list ...\DVBViewer\DVBViewer.exe -x8199 Quote
madbaker Posted May 31, 2008 Author Posted May 31, 2008 BRILLIANT!! -x7 seems to have done the trick, this is just what I was looking for. Many thanks to you! Nick Quote
sibax Posted May 31, 2008 Posted May 31, 2008 WOW, thanks. Can we get complete command line switches list? Quote
Lars_MQ Posted May 31, 2008 Posted May 31, 2008 see actions.ini in the DVBViewer program folder. The number after the = for each action is also a -x commandline parameter. You can use more than one -x in a commandline. example -x1 -x2 -x3 ... Just remember not every combination is usefull Quote
sibax Posted May 31, 2008 Posted May 31, 2008 (edited) @ Lars_MQ & Tjod Thanks for useful information. Edited May 31, 2008 by sibax Quote
Tjod Posted May 31, 2008 Posted May 31, 2008 Take a look in the actions.ini in the DVBViewer folder. All this numbers can be used with the -x parameter. -f fullscreen -m minimize -c DVBViewer Standby warning this parameter kills recording and -c"Channel name" to switch do a channel. Use Channel Shortcutter to generate the shortcut. It is possible to combine multiple parameter ...\DVBViewer\DVBViewer.exe -x37 -x7 Quote
sibax Posted June 1, 2008 Posted June 1, 2008 @ Lars_MQ & Tjod Thanks for the useful information. Quote
