Unicast problems
razvanelgsm
Hello
I can't open settings window for Unicast in v3.9.4.0, in 3.9.2.0 was working perfect.
B.R.
Razvan
you checked your firewall setting?
I have not think need look in firewall because before was working,
but seems here was the problem!
Thx man, problem solved now!
B.R.
Razvan
The options now do a autodiscovery call on opening the network device options, to make it easier for the users. It simply broadcasts a UPD packet with the content "Query for DVBViewer" in the local network and waits for an answer from a netstreaming plugin or dvbserver.
It then lists the found servers so you simply have to click the entry in the server list and all settings are done.
I think I'll make some corrections so that in case the call is blocked it doesn't get upset anymore :blink:
