digidigi Posted June 3, 2008 Posted June 3, 2008 (edited) Hello, Thanks for continue to spoil us with greater and greater solution. However this time I upgraded to DVBViewer 3.9.4 and got in to some troubles. I'm using Hauppauge remote, this remote require the application to be the selected window to work. If I use the mouse and click once on the dvbviwer screen window after I have launched the remote it's working. In all other versions of DVBViwer this have not bean any problem, but in 3.9.4 this does not work before I take the mouse and click on the DVBViewer window. This might not sond like a huge problem, but it's for me since I only use my remote to start/stop and control the DVBViewer, I use no keyboard or mouse on daily use, it's now our primary TV solution on both our TV's. :-) P.S I'm only use OSD mode. /Digi Edited June 3, 2008 by digidigi Quote
digidigi Posted June 4, 2008 Author Posted June 4, 2008 Problem Solved! Unchecked "Allways on TOP" restarted, checked "Allways on TOP" restarted and voila. /Digi Quote
