steviegal Posted June 3, 2008 Posted June 3, 2008 Hello everybody, I have just joined the forum and hello to everyone here. I have a problem after installing DVBViewer and using it with my FireDTV hardware, when I do a scan some of the transponders fail to return any channels. I am based in the UK and using my Sky dish to scan Astra 2D. Have read a couple of posts with a similar problem but their solution does not fix mine. I was wondering if my dish is not aligned correctly but then I have no problem with my other receivers (Sky Pace box and Humax). I get about 600 channels when scanning with Transedit but noticeably BBC2, 3 and 4 are missing as is Luxe TV HD which is what I want. BBC HD is OK. It seems to be certain transponders. Signal is 75%. Anyone any ideas that might help, is there a tweak I am missing with DVBViewer? I am at a loss to know how to fix this. Thanks Steve Quote
steviegal Posted June 4, 2008 Author Posted June 4, 2008 OK have found the problem, it was the DiseqC setting that was incorrect. Quote
