LePouSAT Posted June 4, 2008 Posted June 4, 2008 (edited) Hi guys ! I'm not sure if I write this message in the right place. All my apologizes if I did post in the wrong area. I have a problem ... I can't scan the channels from transponder #23 (11719) to transponder #78 (12728), I mean I can even get the PAT area to become green, it stays red !! But I can get everything from transponders #01 to #22 !! However, I have a standalone sat receiver in another room connected to the same antenna (4 outputs on the antenna) and it receives perfectly the channels that I'm supposed to scan from my PC ... What may I check (except the cable from antenna to PC, I checked it ok !!) ?? Thanks in advance for your help !! LePouSAT PS: I'm using latest DVBP 3.9.4.0 Edited June 4, 2008 by LePouSAT Quote
Scan_Speedy Posted June 5, 2008 Posted June 5, 2008 Frequency 11.750 - 12.7XX is Highband. Have you a Highband = digital LNB ? Quote
