Guest proton Posted June 5, 2008 Posted June 5, 2008 (edited) Hi, Now that I have set up DVBViewer, whenever I change to an HD channel it starts to jump/skip frames. So it's kinda like fast forwaring a DVD where it skips from one frame to another and looks like it is jumping a few frames forwards. When I rebuild the Graph it goes away, but then after a few minutes starts that jumping process. Can anyone help? I have tried all my HD video decoders and different renderers. I am using Vista 64, 4GB, ATI HD 2400 and DVB-S/2 World BDA Tuner card. Do you need any more info? Thanks. Edited June 5, 2008 by proton Quote
Guest proton Posted June 6, 2008 Posted June 6, 2008 Anyone? Oh I forgot to add my processor is an AMD X2 4400+ Is this something that is very easy to fix? Quote
Lars_MQ Posted June 6, 2008 Posted June 6, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Guest proton Posted June 6, 2008 Posted June 6, 2008 OK Thanks a lot, here it is. I bought my DVB-S/2 Card on fleabay and has no name on it. The name that DVBViewer picks up is called DVB World BDA Tuner Filter if that helps. Many Thanks... This is a whole learning experience for me. Quote
