dabade2 Posted June 7, 2008 Posted June 7, 2008 (edited) Here is a little dos batch and instructions to get XMLTVIMPORT working with Freeview in New Zealand, this is useful for those that are using Freeview HD (Terrestrial) since it only includes the EPG for the following 2 programs; and this way you can see the full 7 day EPG like the freeview customers on the satellite see. It's made with a simple batch file, and includes instructions on how to get it working and scheduled (if you want to). Might save you 10 mins work one yourself. Brought to you by the friendly http://epg.pvr.geek.nz/epg/ people, XMLTVImport, and me. Box of birds, bro. Dabade epg.zip Edited June 7, 2008 by dabade2 Quote
PhilW Posted August 9, 2008 Posted August 9, 2008 Works well, but requires a little tweeking if you don't have a standard setup. For Vista 64 OS you will need the appropriate 64bit 7z unzip found at http://www.7-zip.org/ After a standard install copy the 7z.exe file out of the program folder and paste it to the folder where you have the get.bat file... or whereever you have chosen to hold these files. Tx to Dabade2 Quote
