kenmawk Posted June 7, 2008 Posted June 7, 2008 Will you upgrade Web Frontend to support traditional chinese? Quote
Tjod Posted June 7, 2008 Posted June 7, 2008 Did you test this? http://www.DVBViewer.info/forum/index.php?...st&p=187060 And way a new Topic and no answer from you in the first topic? Quote
kenmawk Posted June 19, 2008 Author Posted June 19, 2008 Did you test this?http://www.DVBViewer.info/forum/index.php?...st&p=187060 And way a new Topic and no answer from you in the first topic? Yes, I am already do it. But No traditional chinese supported on web pages. The Language options of configuration can't select traditional chinese. Quote
Lars_MQ Posted June 19, 2008 Posted June 19, 2008 http://www.DVBViewer.info/forum/index.php?...st&p=198838 Don't know if it needs Big5 or something else, just try. Quote
