What's "New Tuning Method?
pearpear
In the options dialog and hardware page, there is a check box "New Tuning Method", but I cannot find any documentation about this option?
What's the usage and meaning of this option?
Thank you very much!!!
It means that DVBViewer communicates with the BDA driver more directly, hence bypassing the Microsoft Network Provider filter resp. its interfaces. Usually this method is a bit faster (if it works).
Thanks for your informative explanation.
How can I know if it work or not?! Would it have any messages if do not work?!
If it doesn't work you will notice.
