krazykid Posted June 8, 2008 Posted June 8, 2008 (edited) I have a problem that seemed to be raised a few months ago and solved by an update. I have just purchased DVBViewer for use in NZ and can scan the channels ... ...but when I try and select a channel it freezes and the PC requires a reboot Sometimes I get a picture (one frame) before it crashes but it always crashes The Turner card is new as well to me (but is working for others in NZ I have seen) - it is a HVR-2200 Driver v3.3 and seems to run fine. the Debug file ends at 08.06.08 22:16:04 AddVideoRenderer Add EVR I have tried VMR9 and overlay etc but no sucess - always crashes. The grahics card is a Gigabyte 8600GT The motherboad is a Gigabyte GA-73PVM-S2H with an intel Dual core 6550 CPU I somebody has some suggestions of what I can do or look for a solution. Many Thanks for reading. Attached is the support file EDIT: Also attached the debug file with a differnt codec tried. Got one step more then froze again support.zip debug.log Edited June 8, 2008 by krazykid Quote
