A little help with decoders & rederers please......
Kevin Bishop
I have just re-installed DVBViewer 3.9.4.0 after some instability problems.
I use Intervideo & Cyberlink decoders. When I built DVBViewer I set all audio & video decoders to Intervideo which seems to give me the best picture quality, but I get no DVD audio. Sat TV & recordings are fine.
I have changed the the decoder in the options for both DirectX and DVD but no change. When I check View-Filters it still shows Intervideo Audio Decoder.
Could somebody spend a few minutes explaining how this all links together, because I am struggling to understand?
Thanks in advance.
I have no experience with Intervideo decoders, always use Cyberlink for hardware acceleration, but I would suggest you install AC3Filter audio decoder from here.
Edited by mr_chaela
Thankyou.
that resolved it.
Kevin
