Pause/Play
iSLK
My problem is only with HDTV;
SD is without problem,
if I press pause on a channel the timeshift is active...that's ok
but after I press Play and program is continue without video(black screen), the audio is ok. .....?
I have SkyStar HD2, Vista32, renderer EVR, Cyberling PDVD7/8 codec, AtiRadeon3200HD, MB 780G, registred DVBViewer3.9.4.0
Thank you for your solution.
iSLK
Edited by iSLK
I solved my problem,
i changed Analog to Digital(HDMI) cable to LCD .
No it doesnt go...still problem with black screen after play.
Edited by iSLK
