Zen Posted June 11, 2008 Posted June 11, 2008 Hi, I receive somme channel with a perfect video but with incomprehensible sound. I verify all parameters (PID, .... ) on these channel and all are Ok. Is there anybody who know this problem? A clue will be welcome Thanks for your help Quote
Lars_MQ Posted June 11, 2008 Posted June 11, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Zen Posted June 13, 2008 Author Posted June 13, 2008 Hi, I joint the report of support tools DVBViewer 3.9.1.1 OS Windows Vista X64 SP1 Motehrboard : Gigabye AMD AthlonTM 64 X2 Dual-Core processor Processor : Athlon X2 5000+ Ram : 4 Go Graphic card : ATI RADEON HD 2600 XT I have another pb: I need to upgrade my powercam 3.7 -> HD2.0 but DVBViewer don't see my power cam in the CAM interface menu and upgrade download from stalletite dont perform. However, I receive encrypted channel with 3.7 version Quote
Zen Posted June 13, 2008 Author Posted June 13, 2008 ------------------------------------------------------------------------------- Digital Everywhere Support Report: (1. 0. 8. 0) ------------------------------------------------------------------------------- Generated on (Y/M/d): 2008.06.13 FireDTV / FloppyDTV devices: ------------------------------------------------------------------------------- devices found: 2 Status for device 1 Model : FloppyDTV S2 GUID : 0x00128724040007D7 HW Ver.: 01.24.04 FW Ver.: 1.0.1 Build 13440 Driver : 5.0.1 Frontend Status: Sig.Str.: 77%, BER: 0 Locked : YES CAM Module: PowerCam V3.7 Status for device 2 Model : FloppyDTV S2 GUID : 0x00128724040007D9 HW Ver.: 01.24.04 FW Ver.: 1.0.1 Build 13440 Driver : 5.0.1 Frontend Status: Sig.Str.: 100%, BER: 0 Locked : YES CAM Module: PowerCam V3.7 Windows System Information: ------------------------------------------------------------------------------- OS Path: C:\Windows OS Version: Microsoft Windows Vista, Service Pack 1 (Build: 6001) OHCI Controller: Manufacturer: Texas Instruments Description: Contrôleur hôte Texas Instruments IEEE 1394 compatible OHCI (Open Host Controller Interface) MCE Plugin: ------------------------------------------------------------------------------- No Plugin Version found! No Service found! Program files path: 'C:\Program Files (x86)' FireDTV Transponder List: ------------------------------------------------------------------------------- No Transponder Lists found! FireDTV Tools: ------------------------------------------------------------------------------- No running FireDTV tools found Quote
