SAPPHIRE ULTIMATE HD 3850 512MB GDDR3 PCI-E
ramonchin
Hi
I've just installed this new card with Catalyst 8.5. H264 looks too much procesed, though great quality. I'm using Cyberlink codec. Vista 32bits SP1
What are the best option in Catalyst for the best video PQ?
Actually it's using 25-30% CPU (with EVR).
In the other hand, what Should I set for 0-255 Full RGB, I've noticed grey bars.
What codec should I set highest merit in order to get VC-1 + DXVA ??
Thanks.
Edited by ramonchin
Hi
Thanks.
"UseBT601CSC" =1" registry fix for 0-255 levels, doesn't work on Catalyst 8.5 :D Blacks are still greyed on SD films :D
