iSLK Posted June 11, 2008 Posted June 11, 2008 (edited) i am using decoder CyberLink H.264 Video Decoder v2.2.0.527 for HDTV, everyting works fine, but after pause and play... is video black, audio is ok. Where is problem ? if i use decoder ArcSoft Mpeg2,AVC Decoder v2.25.83.43 timeshift is ok, but i can't see OSD. OS Wvista32bit EVR, AtiRadeonHD3200,CPU AMD, MB ASUS 780G, registred DVBViewer 3.9.4.0 support.zip Edited June 11, 2008 by iSLK Quote
habibm Posted June 16, 2008 Posted June 16, 2008 i am using decoder CyberLink H.264 Video Decoder v2.2.0.527 for HDTV, everyting works fine, but after pause and play... is video black, audio is ok. Where is problem ? if i use decoder ArcSoft Mpeg2,AVC Decoder v2.25.83.43 timeshift is ok, but i can't see OSD. OS Wvista32bit EVR, AtiRadeonHD3200,CPU AMD, MB ASUS 780G, registred DVBViewer 3.9.4.0 I have the Gigabyte 780G mobo. With the Arcsoft decoder EVR causes OSD to not appear, the Cyberlink H.264 decoder does exactly what you describe, plus it crashes when ITV HD is selected. In the end I opted to use Overlay Mixer with the Arcsoft decoder, the OSD appears and is great. Quote
