MuMolo Posted June 12, 2008 Posted June 12, 2008 Hello, i just bought DVBViewer, but i cant figure out which tunertype i've got.. I have a DVB-T Antenna so which of these Tunertype's should i choose: Antenne: Cable, Satalite, Terrestrial or ATSC ? Regards Steffen Andersen Quote
Mr Rimmer Posted June 12, 2008 Posted June 12, 2008 Hello, i just bought DVBViewer, but i cant figure out which tunertype i've got.. I have a DVB-T Antenna so which of these Tunertype's should i choose: Antenne: Cable, Satalite, Terrestrial or ATSC ? Regards Steffen Andersen DVB-T = Terrestrial DVB-S = Satellite DVB-C = Cable ATSC = ... ATSC (I think) ;-) HTH Quote
MuMolo Posted June 12, 2008 Author Posted June 12, 2008 I get those.. but i live in Denmark... What do i do ? Quote
Lars_MQ Posted June 12, 2008 Posted June 12, 2008 Well last time I heard denmark is part of europe so use terrestrial(Eur) Quote
MuMolo Posted June 12, 2008 Author Posted June 12, 2008 doh.. Ofcourse.. Its working great now, i love this program.. Quote
thl Posted October 12, 2008 Posted October 12, 2008 Hello Steffen I just installed DVBViewer, but can't setup the channals for DVB-T. I have a Hauppauge WinTV-HVR-1700 tuner and the channals in Windows Media Player works fine but without subtitles on DR1 and TV2. Can you give me som hints on how to setup the DVBViewer ? Regards Thomas Quote
Salvatore Posted October 13, 2008 Posted October 13, 2008 I get those.. but i live in Denmark... What do i do ? I recently purchased a Fotocom super hdtv usb stick(third generation of something), i have realised Hong kong is part of europe too, cause that's the same tuning setup i have used. but the latest version DVBViewer only manage to grab the chinese version of the EPG which my computer can not display it properly, where the 3.4.9.200 version manage to grab english version. Can you help with either of the problem? Quote
Salvatore Posted October 15, 2008 Posted October 15, 2008 The beta version has solved chinese character display problem, now for the english epg option!? then maybe italian. Quote
etcoil Posted October 28, 2008 Posted October 28, 2008 Hi, all i live in hong kong and just bought the software, but i don't know what choose in the "Which DVB System do you want to scan?" My TV tuner is AverTV DMB850 Plus, the Singals DMB-TH. thanks etcoil Quote
