alain_sat Posted June 12, 2008 Posted June 12, 2008 Hi, I'm new and try at the start to have image on HD FTA channels on Astra 19.2 like Astra HD and Annixe HD. As you can see the channel is locked but no picture. I'm using a Dual Core PC. Windows XP Pro SP2. AVC Core Codec installed for mkv H264 playback. (alltough VLC works better on Linux). I first installed the drivers and software that came with the USB Tuner. I use Cyberlink for Technotrend filter. I downloaded the program this week, so it should be latest version. I get picture on FTA DVB-S channels I know it's on the original software but it works in DVBViewer also. Thanks helping a newbie in DVB-S(2) world (I never used the 4 cards that are in the PC) As I'm not home now I can't give more precise information, if needed please tell me what you need more. Quote
feixen Posted June 12, 2008 Posted June 12, 2008 Hello mate. you`ve find the right forum place. Download this and copy in your main-directory from DVBViewer. execute it .. and poste here the support.zip -file. Quote
alain_sat Posted June 12, 2008 Author Posted June 12, 2008 (edited) Thanks for your answer, I will have a look at it. But, it works and I'm not really sure why. I was playing around with the Preview and that worked, so I new the pictures were decoded. Then playing with the zoom function gave me pictuyre, I still don't know why. I noticed the hardware wasn't really Ok to play it well. I do some recordings now to see what it will look like on my multimediaplayers Popcorn and Egreat. Now my next step will be to connect it to my gboxservers on Dreambox and TripleDragon. support.zip Edited June 12, 2008 by alain_sat Quote
feixen Posted June 12, 2008 Posted June 12, 2008 I noticed the hardware wasn't really Ok to play it well. your CPU Speed: 2999 Mhz looks slow. otherwise try (if you can) the ---> CyberLink H.264/AVC Decoder (PDVD7) --> or upper ver. work here like a charm @ CPU: AMD Athlon 64 X2 Dual Core Processor 4800+ Quote
alain_sat Posted June 13, 2008 Author Posted June 13, 2008 your CPU Speed: 2999 Mhzlooks slow. otherwise try (if you can) the ---> CyberLink H.264/AVC Decoder (PDVD7) --> or upper ver. work here like a charm @ CPU: AMD Athlon 64 X2 Dual Core Processor 4800+ I'll give a try this evening. I tried again this morning and it worked well on the latest station i tried yesterday (Astra HD). Then I turned to Astra 23.5 and scanned and couldn't make it work anymore. Even not on SD channels. In preview I got picture. I trasnfered the files I recorded yesterday to my Network Media Tank (eGreat) and he played the files very well on my LCD. The codec you are talking about is probably the same as the Core AVC I use to watch mkv files. Could I solve it with a better vga card? I was actually planning to make a barebone PC to put in the living with hdmi support to connect to my LCD TV. But as I read you, it will probably be allmost impossible? I also have Linux on this PC and noticed mkv files played much better with vlc under Linux, is this an option? What viewer software would you suggest? Quote
alain_sat Posted June 13, 2008 Author Posted June 13, 2008 Just an extra remark, during installation I saw a message from the COm server that said that my hardware wasn't compatible?? Quote
alain_sat Posted June 14, 2008 Author Posted June 14, 2008 So I made some changes but still not very good. <settings> <section name="MPEG"> <entry name="Videocodec">CyberLink Video/SP Decoder (PDVD7)</entry> <entry name="Audiocodec">CyberLink Audio Decoder (PDVD7 UPnP)</entry> <entry name="AC3codec">CyberLink Audio Decoder (PDVD7 UPnP)</entry> <entry name="H264codec">CyberLink H.264/AVC Decoder (PDVD8)</entry> <entry name="Output">1</entry> <entry name="DetectVideo">0</entry> <entry name="DetectAudio">0</entry> </section> Do I have to consider it's a hardware problem? CPU is allmost at 100% If that is the answer how can I solve it? VGA card with hardware decoding of H264? Thanks. Quote
alain_sat Posted June 14, 2008 Author Posted June 14, 2008 So tested on my work laptop and it works well. ------------------------- MPEG2 Video Decoders: ------------------------- InterVideo Video Decoder V5.0.11.563 (beta): 00700000 CyberLink Video/SP Decoder (PDVD7) V8.1.0.1026: 00602000 Nero Video Decoder V5.1.2.0: 00600000 Nero DVD Decoder V5.1.2.0: 00600000 CyberLink Video/SP BD-HD Decoder (PDVD7.x) V8.1.0.6031: 00600000 Nero Video Decoder HD V5.1.2.0: 00400000 ------------------------- H264 Video Decoders: ------------------------- CyberLink H.264/AVC Decoder (PDVD7.x) V2.1.0.1108: 00600400 ------------------------- MPEG Audio Decoders: ------------------------- MPEG Audio Decoder V6.5.2600.3367: 03680001 InterVideo Audio Decoder V5.0.11.563 (beta): 00700000 CyberLink Audio Decoder V6.1.0.4701 (beta): 00601000 Nero Audio Decoder 2 V5.1.2.0: 00600000 CyberLink Audio Decoder (PDVD7 UPnP) V6.0.0.1803 (beta): 00200000 ------------------------- AC3 Audio Decoders: ------------------------- InterVideo Audio Decoder V5.0.11.563 (beta): 00700000 CyberLink Audio Decoder V6.1.0.4701 (beta): 00601000 Nero Audio Decoder 2 V5.1.2.0: 00600000 CyberLink Audio Decoder (PDVD7 UPnP) V6.0.0.1803 (beta): 00200000 ------------------------- AAC Audio Decoders: ------------------------- CyberLink Audio Decoder V6.1.0.4701 (beta): 00601000 ------------------------- System: ------------------------- DVBViewer Version: 3.9.4.0 DVBViewer Size: 1.373 ttBdaDrvApi_Dll Version: 1.0.1.15 DVBSource Path: C:\Program Files\DVBViewer\Filters\PushSource.ax DVBSource Version: 3.0.2.0 DVBCOMServer Path: C:\PROGRA~1\DVBVIE~1\DVBVIE~1.EXE DVBCOMServer Version: 3.9.4.0 OS: Microsoft Windows XP Professional Service Pack 2 (Build 2600) DirectX: 9.0c Memory: 1006 MB CPU: Intel® Core2 Duo CPU T7100 @ 1.80GHz CPU Speed: 1795 Mhz CPU Count: 2 Videocard: Mobile Intel® 965 Express Chipset Family Version: 6.14.10.4814 I think my desktop will need a format C. Quote
feixen Posted June 16, 2008 Posted June 16, 2008 CPU is allmost at 100% If that is the answer how can I solve it? VGA card with hardware decoding of H264? Thanks. yes ... latest Hardware can do this very well ... pls update RaM, CpU and grafik-adapter... or maybe try your other solution. Quote
