Ycke Posted June 12, 2008 Posted June 12, 2008 I would like to se information about the current watched program, from a menu (so I am able to link it to the info ("i") button the MCE remote) The information screen should, be exact same as the small screen in button, showed when changing channel. (channel icon, info of current program, start- & end-time of current program, info of next program, start- & end-time of next program) Maby this function already exists, but I haven't been able to find it....??? Quote
Ycke Posted June 12, 2008 Author Posted June 12, 2008 Thanks for a quick replay. But the problem is that OSD-OK shows a small window, with commands to timeline: pause, forward etc And thats not what I am after... Any other suggestion? Quote
ardua97 Posted June 13, 2008 Posted June 13, 2008 Thanks for a quick replay. But the problem is that OSD-OK shows a small window, with commands to timeline: pause, forward etcAnd thats not what I am after... Any other suggestion? this may be because you have enabled timeshift to see the osd while is enabled timeshift you have to edit the setup.xml following the instruction of the Tweaks.txt in program folder your specific setting is the first where say TimeshiftEPGdisplay Quote
