nea Posted June 12, 2008 Posted June 12, 2008 Hi, I searched in the forum and google but maybe I am using the wrong words to describe my desire, but I am serious: Is it possible to somehow set a flag to continuously play all files in a folder? Because I set my Movies folder into the system, am entering it by the menu and playing say one Video file. If it ends nothing happens, it just stays still, stopped. What do I have to set/do that it will play the next file in the folder. Big thanks in advance! Quote
kubichris Posted November 24, 2012 Posted November 24, 2012 Hi all! I have a same problem... Any suggestion? Quote
Gioxy Posted November 24, 2012 Posted November 24, 2012 (edited) You can use the Playlist: once opened form DVBViewer menu you can fill it with first button on bottom (Add Item, Ctrl+A), select all folder's files and load them at once; then you can set (also from OSD) repeat playlist, random play, save the playlist etc. Edited November 24, 2012 by Gioxy Quote
