Laserwave Posted June 13, 2008 Posted June 13, 2008 Hi there... sorry if this a dumb one, but I've got a 3-LNB, fixed single-dish installation, with LNB1 being ASTRA 19.2, 2=HotBird 13 and 3=Eutelsat W2 16. I can't find a way to scan the third one, and can only scan and watch through Astra and Hotbird. All DiseqC options (Pos A/B, Opt A/;) refer to LNB 1 and 2. How can I scan channels for the Eutelsat W2 on LNB 3? Thanks a lot Quote
Darwin Posted June 14, 2008 Posted June 14, 2008 (edited) The only important question: Type of DiSEqC switch(es) ? Edited June 14, 2008 by Darwin Quote
Laserwave Posted June 14, 2008 Author Posted June 14, 2008 Thanks. Sorry, I know almost nothing about satellite equipment so I'll refer the "Antenna Setting" menu of my Humax 5400Z, which is also connected to the same dish, and can see all 3 satellites. 1. Antenna Alternative = 3 (1=Astra, 2=Hotbird) 2. Satellite Name = Eutelsat W2 3. LNB Frequency = Universal 4. 22kHz Tone = Disabled 5. 0/12 Volt Switch = Disabled 6. DiseqC Input = DiseqC C (the other available options here are: "DiseqC A", "DiseqC B", "DiseqC D", "Tone Burst A", "Tone Burst B" and "disabled") 7. Motorised Switch = Disabled Quote
Darwin Posted June 16, 2008 Posted June 16, 2008 I try to translate: Humax ------> DVBViewer =================== DiSEqC A -> PosA/OptA DiSEqC B -> PosB/OptA DiSEqC C -> PosA/OptB DiSEqC D -> PosB/OptB Check in DVBViwer for all LNBs: LOF1 = 9750 LOF 2 = 10600 LOF SW = 11700 (== universal LNB) and don't forget to check the right "Pos/Opt to Sat"-Choice everytime you scan. (DVBViewer forgets to persist... ) Quote
