plugins in subfolders
emplos
DVBViewer doesn't find plugin if it's in subfolder of DVBViewer\plugins
With many plugins folder looks a little messy.
looks messy? you must be joking :blink:
But on the other hand I know all is well as long as people have only problems with messy looking folders.
I know how to change it: don't look into the folder. you do not have to live in it and you do not have to hang pictures of it on the walls. So who cares?
Thans for "help".
It's hard to find one file (ex. config file) in folder with 100 files.
It would be much easier with subfolders.
LOL
This is "support".
I didn't paid money to be treated like intruder.
BTW. Don't play "great admin". If don't want to help than just don't answer.
Hello !
Please calm down.
The question is :
How and for Heavens sake needs 100 (hundret) Plugins for the DVBViewer?
I only really know 3-10 which are usefull.
The rest of most plugins is already implemented in the DVBViewer itself.
Nevertheless: INstead of requesting a somewaht unike feature please try workarounds
e.G. a subfolder on your desktop were the links to your configuration files are stored.
So you poonly have a tidy folder with files you need.
AND as the biggest advantage you can store them in so many siubfolder levels you like.
That was useful , or not ? :blink:
Hello !
Please calm down.
The question is :
No 100 plugins. 100 files (one plugin - ~5-20 files).
Why "INstead of requesting a somewaht unike feature please try workarounds"? I thought it's topic where I should put some ideas to make program better (ALTDVB already has this function).
Is this realy too hard to implement simple function like this?
Edited by emplos
Another disadvantage is overwriting files with the same names (ex. language files), but from diffrent plugins.
