StephaneM Posted June 15, 2008 Posted June 15, 2008 Hi, In my DVBViewer Recorder plugin for SageTV (DVBViewer being used as a recording engine for SageTV) is using the "AddRecordingFolder" COM method to add a folder in the DVBViewer config so as it can record in the path I choose. Since DVBViewer 3.9.4 this method doesn't work anymore (it don't crash and even return the folder index), for example: Dim oDVBViewer Set oDVBViewer = GetObject(,"DVBViewerServer.DVBViewer") Dim oTimerCollection Set oTimerCollection = oDVBViewer.TimerManager WScript.Echo oTimerCollection.AddRecordingFolder("C:\Videos") does echo "3" if I already have two folders defined in DVBViewer, however "C:\Videos" is not added... Is it just me, or is it really broken (not that many users that use my plugin are complaining that DVBViewer is not recording in the right folder, so I think it also happens on their setup too) Regards, Stéphane. Quote
