Wich Visual C++ version?
trifon33
Hi follks,
There is now download link for Visual C that come with DVBV 3.9.4.0
I found I had installed it twice; once from the DVBV forum and now while installing 3.9.4.0.
The funny thing is both were side by side in my add/remove manager. All 2005 version but with different file size.
Microsoft download offer several versions of Visual C++; almost one per year.
Is that right to install the 2008 version in place of 2005'?
Besides, is there any relationship between .NET 3.5 ans Visual C++??? I mean, is it included in .NET now???
I am under XP SP3 now
THanks
Edited by trifon33
As written on the download page, these are needed files by third party dlls (KNC1, Technotrend). The ones downloadable in the setup do work with this dlls.
If you want to fiddle around do it on your own risk if it doesn't work out don't exspect help.
THanks Lars_MQ, but if Visual C++ 2008 or earlier version is needed by another application, is it possible to install 2005 one too without risks???
