Lime Posted June 19, 2008 Posted June 19, 2008 (edited) Hi! Is there any way I can "record in the background"? What I mean by that is that I dont want DVBViewer to "steal" CPU power by showing video and audio. Hope you know what I mean Edited June 19, 2008 by Lime Quote
hdv Posted June 19, 2008 Posted June 19, 2008 Hello, use View -> Close Graph, after you begun a recording, if you want rebuild the graph, use Channel -> last channel. you can learn a key for this actions. Last Channel is also in the Options -> Input list if you want use clos Graph with a key you must use the Action Editor (click sorry only in german available) and use "Stop Graph" from the dropdownlist in Aktioneditor if you want to make a Timer use "Disable AV" in the Timer window, if you use Options -> Recordings -> "Default disable AV" every timer will have Disable AV automatically PS: there is also a Recordingservice available, for make recordings without DVBViewer -> http://www.DVBViewer.info/forum/index.php?showtopic=19629 Quote
Lime Posted June 19, 2008 Author Posted June 19, 2008 (edited) You answered my question really good! Many thanks for that! The recordingservice is exactly the thing I wanted Edited June 19, 2008 by Lime Quote
