NetStream cannot stream HD video?
I'm user from HongKong, I can't stream the signal of High Definition TV by using NetSteam.
When I connect to steam server by VLC player, VLC player display a frozen screen while sound can stream normally.
What should I do??
..it seems a problem of VLC. Try another client e.g. DVBViewer.
How can I use DVBViewer as client?
Select the unicast device (settings -> options -> hardware). If you stream from another DVBViewer via the netstream plugin, the client has to be tuned to the same channel. When using the dvbvserver you can switch channel on the client. The dvbserver only works with DVBViewer clients and not with e.g. with the vlc.
Got it! Thanks
