DVBviewer launch fails
kouniao311
My DVBViewer V3.9.4.0 can't be successfully launched. It always pop up a window say that " Error in Userdata! Please start the DVBViewer as Administrator!"
My operating system is Vista Home Premium, the user account is administrator. I tried to uninstall then re-install it but still doesn't work.
Does anyone can help me to solve this problem? thanks
The userdata is invalid. Deinstall and then install und enter your username and password, you received when you bought the DVBViewer, exactly as written in the confirmation email.
Thanks for your quick response.
I tried, I entered all my username and password which exactly attached in the confirmation email. Unfortunately it still doesn't work.
Now I feel really frustrated on it, any other way that I can try?
Edited by kouniao311
Are you using Vista? do know that default login is with restricted rights.
trye with administrator rights or expzand the restricted ruights regarding DVBViewer.
I just right click DVBViewer and select "run as administrator", that's it.
Now I feel much better, thank you so much.
  • 1 month later...
I have the same problem since upgrading to v. 3.9.4.0.
10 days ago I resolved the problem by removing the installation and running setup again. But yesterday the problem was back: DVBViewer prompts for Username and password. I didnt have the info by hand so I selected close. Relauncing DVBViewer gives: Error in Userdata.
This time reinstalling was unsuccessfull.
But placcing the previous version in the DVBViewer directory and running it solves the problem. at least for the moment.
Now the latest version can start againg!
I hope this is helpfull.
Using Vista Home edi. premium.
Best regards
Poul Heide
Edited by Heide
No support for a version this old. Deinstall it including the program and userdata folder, download the current version and install it.
We are using V3.9.4.0 - Is there a newer version?
No there is some thigh wrong. Some Parts are new but the DVBViewer is old. Reinstall the current version and do not replace files in the DVBViewer Folder with old versions.
