sky star hd2
Yes -> same as TwinHan 1041.
thank You very much for Your answer. Do You know also if orginal remote control for TT SS HD2 works with dvbwiever ?
What do you mean -> TT?
Since I have no HTPC it isn’t necessary for me to use a remote control.
I have tried only once the IR receiver (2.5 mm jack) for my AzureWave (TwinHan 1041) and could operate some commands, but the most should be learned in DVBViewer.
